Thread: AutoTop DIY
Old 06-01-2014, 08:24 PM   #11
Shehadehd
Shehadehd's Avatar
It is simply a electronic switch, the 1K resistor is a current limiting device to protect the transistors from drawing too much current. It would help if the writer listed the EBC codes on the drawing. I will try to open this up a bit. The 1K resistors go to the Base of the transistor, it looks like the Emitter is grounded and the Collector supplies switched power to the harness. The Arduino can only handle a few milliamps of current so the transistors are used like electronic relays to trip the regular relay in the car.
I just wanted to make sure that the Base voltage was okay to put the transistor into a saturated state and that the resistor wasn't too small and causing the output pins on the board to overdrive or not providing enough base current for the collector current needed.
Shehadehd is offline   Reply With Quote
