Thread: AutoTop DIY
Old 06-01-2014, 08:10 PM   #11
JayG
On the slippery slope
JayG's Avatar
I bet you have the Emitter and the Collector reversed on the transistors, the Base is almost always in the middle
I have already tried reversing the transistors.
It is simply a electronic switch, the 1K resistor is a current limiting device to protect the transistors from drawing too much current. It would help if the writer listed the EBC codes on the drawing. I will try to open this up a bit. The 1K resistors go to the Base of the transistor, it looks like the Emitter is grounded and the Collector supplies switched power to the harness. The Arduino can only handle a few milliamps of current so the transistors are used like electronic relays to trip the regular relay in the car.
I did verify the pin out with the data sheet of the part
With the part I have the collector is grounded and emitter goes to harness
Is that wrong?
2004 996 Targa Tip
Instructor - San Diego region
