Thread: AutoTop DIY
Old 06-01-2014, 07:38 PM   #10
Shehadehd
Shehadehd's Avatar
I used the exact transistor you spec'd and 1k resistor as you listed. In reviewing your parts list,you did mention that you thought it was a 1 k resistor. I have no idea how to check what value the transistor needs
I double checked the transistor wiring and it is correct
The clicking is both on open and close
Haha, I didn't write the thread. I can look through the transistor to see if it'll theoretically work but the OP got it working in his so it's probably fine. It looks like he gave a top down view of the transistor in the wiring diagram so be sure that you have the left most pin ( if you're holding the transistor with the curved side towards you) wired to the switch harness.
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
Shehadehd is offline   Reply With Quote
