Thread: AutoTop DIY
Old 06-01-2014, 06:31 PM   #11
JayG
On the slippery slope
JayG's Avatar
Originally Posted by Shehadehd View Post
More likely bad pins than a bad board. You can always try four different pins and see what happens. If both opening and closing the top acts the same, then maybe the transistors aren't working properly. Make sure you didn't wire them backwards... you might also want to check to see if the 1k resistor to the transistor is an acceptable value for the transistors you're using.
I used the exact transistor you spec'd and 1k resistor as you listed. In reviewing your parts list,you did mention that you thought it was a 1 k resistor. I have no idea how to check what value the transistor needs
I double checked the transistor wiring and it is correct
The clicking is both on open and close
2004 996 Targa Tip
Instructor - San Diego region
