Only problem with disconnecting the battery is you clear all the settings in the ECU, making it re-learn mapping when you drive again. This could be troublesome if the ECU is compensating for conditions outside the normal operating range. It also takes numerous cycles to "ready" all phases for emissions.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
