Old 05-30-2014, 10:22 AM   #11
BoxsterSteve
still plays with cars...
BoxsterSteve's Avatar
Originally Posted by recycledsixtie View Post
Thanks all. I have put in an order for water pump(plastic impeller), gasket and thermostat.
Cheers, Guy.
Recycled,
Go with the low-temp thermostat, and do the work yourself, it's too easy not to DIY.
I too was on the fence about doing the work you're about to undertake. I had no receipts from the PO regarding replacement, so I assumed, correctly as it turns out, that I was still running the original pump.
Coolant was also changed, as it was 14 years in the vehicle, and I went with a LN 160F thermostat.
For working on jackstands and only with hand tools, I got 'er apart, drained and back together in 4 3/4 hours. I had to add another half hour for the borrowed vacuum fill tool and I was all finished.
Asides from the under-vehicle access, it really was an easy DIY.
I had no 1/4" drive torque wrench, so the water pump bolts got snugged down and another quarter turn. No leaks after 2 months, so I'm not expecting any.
Six speed 2000 Boxster S
