Old 05-29-2014, 06:55 AM   #1
epapp
epapp's Avatar
Most likely the tank has cracked. But, it could be the cap has failed and coolant boiled over and exited through the overflow hose, which also would leak in the same general area as a cracked tank (somewhere infront of the right rear). If you check the bottom of the trunk, it will be more clear which has happened
epapp is offline   Reply With Quote
