Old 05-28-2014, 07:08 AM   #6
Mark_T
You may want to do a search and then re-think the cold air intake. There is really nothing to be gained and you may even compromise your performance.
I'd suggest you spend a few evenings reading back through the forum, primarily the "general" and "performance" sections. You will gain much insight and guidance on where and where not to spend money. Using the search button will help you to avoid asking common questions that have already been asked and answered countless times.
For instance, please don't ask what kind of oil or tires to buy, why your right rear fog light doesn't work, or what that pointy probe-like thing is in your right front intake grill, otherwise we will know that you haven't done your homework.
The emblem question is a good example. A search would have told you that you use dental floss to work the old emblem off and you clear up the residue with rubbing alcohol or brake cleaner. The new emblem is self-adhesive. Consider the cleaner de-badged look. Sure makes polishing the trunk lid easier!
Welcome to the forum!
'99 black 986
