Old 05-28-2014, 07:17 AM   #2
Ian c
Yes .
I posted recently about spacers , I'll go take a look and paste it here .
Buy quality .....
Bear in mind porsche 5mm come with longer studs but iirc you have to buy a set of 4 .
(I may have a spare pair to sell)
H&r , RuF charge extra for longer studs iirc .
If you go around 15mm on the rear they will/could/should be bolt on "adapters" which will convert you to studs .
You must use steel "open ended" nuts ....
Ian c is offline   Reply With Quote
