Originally Posted by Gelbster
The reman is only as good as the rebuild guy and the parts he uses.You would need a very good warrenty!
The other option was mentioned earlier-swap your internals into a good case. That should be much easier to find than the alternatives.
Thank you will check with my mechanic on that
