Old 05-24-2014, 07:39 PM   #10
ChrisZang
ChrisZang's Avatar
So I need Boxster buddy help....
Bought the type that uses the air compressor to create a vac that drops fluid into a resivouir.
Worked great. Pulled a lot of dirty fluid through. Kept res full, always closed bleeder before stopping suction.
Now pedal drops 2/3 way down then starts some braking. Second pump works great and solid. At a red light it does not drop pressure. Once moving, it needs that second pump each time.
Also had front rotors turned.
Ideas??
You managed to get air in the system, go back to start
