Originally Posted by jdlmodelt
Ok, so the pipe clamp doesn't fit the bypass pipes since the bypass pipe end is a larger diameter than the original cat pipe diameter. SO, how the heck is everyone one getting the pipe clamp back on with the new bypasspipes? I put my cat back on the driver's side after I started up with a kluge fix with the bypass pipe that was releasing quite an exhaust leak. Anyone have a good fix?
You should have an adapter with the kit. The slotted side of it should go over the test pipe and the smaller end fits inside the original pipe clamp. It takes some shimmying. It's a bit easier to clean it first before trying to adjust it under the car.
Speedy2000, thanks for your help. I was finally able to attach the test pipes. Turns out I just needed to add a little more elbow grease. it sounds great!
