different pipe diameters
Ok, so the pipe clamp doesn't fit the bypass pipes since the bypass pipe end is a larger diameter than the original cat pipe diameter. SO, how the heck is everyone one getting the pipe clamp back on with the new bypasspipes? I put my cat back on the driver's side after I started up with a kluge fix with the bypass pipe that was releasing quite an exhaust leak. Anyone have a good fix?
