Old 05-23-2014, 08:22 AM   #15
JFP in PA
Thanks for the words of encouragement XCELLR8.
Its nice having the tools (Durametric) but if you dont know how to interpret the data your not getting maximum bang out of it.
I bought a couple cigars last evening for my DIY smoke machine for vacuum leak detection. That should be amusing and of course a video will follow with the results.
I'll be getting a Fuel pressure gauge this evening and have read how to measure flow rate....so many liters per minute although I forget the exact number but will document it here when I do the test. (No codes yet)
The car is at 74K miles so replacing a few parts was due anyway so it wasn't unexpected. However the failed AOS precipitated this issue which I find rather odd, so I am expecting to see some vacuum leaks in that area and would make a lot of sense.
Not really expecting a fuel pressure issue but since its easy to check I might as well do it.
I did read something about the Fuel injector rail port where the pressure guage would connect to and wondered if a new washer was necessary when replacing the cap? I read that its a Schroeder valve ?
It is a metric Schrader valve, and the cap with washer is supposed to be replaced each time, but you can usually get away with taking it off once or twice before it starts to leak. Caps are cheap.
