Old 05-22-2014, 10:42 PM   #11
danch
danch's Avatar
My car came with Cruise, my Tech said it was easy to turn on the OBC...will the stalk just plug in ??
I added a OBC Stalk and computer to my E36 years ago, I had to take the dash out and change a good bit of the wiring...but it was not a tough job at all.
The stalk will attach to the existing steering column but you will need to either make the hole for the stalk to come through the rubber or buy the 2 opening rubber.
Also you will need to make up a loom to connect the stalk to the cluster as per :
http://www.pelicanparts.com/techarticles/box_OBD_Mod/box_obd_mod.htm
danch is offline   Reply With Quote
