Thread: cat test pipes
Old 05-22-2014, 08:56 AM   #12
Shehadehd
Shehadehd's Avatar
Originally Posted by Speedy2000 View Post
I disconnected the cat pipe from the U-Pipe and got the u out first. Then i let the cat fall so the cat was actually facing toward the ground. With the cat facing the ground i pulled it straight back and slightly downward. Took a little jiggling but it does come out. Hope this helps
Does that mean you hammered or cut these studs off? Because I can't twist the cat at this point
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
Shehadehd is offline   Reply With Quote
