Thread: cat test pipes
Old 05-22-2014, 09:50 AM   #3
Speedy2000
Originally Posted by Shehadehd View Post
Cool thanks, I've gotten to the point of remove all the nuts and bolts but I can't get the cat and pipe out of the car lol. The bottom two studs are still on the adapter and the exhaust is getting stuck on the hook piece near the muffler. I'm starting to consider dropping the entire muffler... Is there another way around it?
I disconnected the cat pipe from the U-Pipe and got the u out first. Then i let the cat fall so the cat was actually facing toward the ground. With the cat facing the ground i pulled it straight back and slightly downward. Took a little jiggling but it does come out. Hope this helps
Speedy2000 is offline   Reply With Quote
