Thread: Top won't drop.
Old 05-21-2014, 03:58 AM   #3
ppbon
ppbon's Avatar
Originally Posted by Idaho Red Rocket 3 View Post
Parking brake like comes on. I tried it again tonight. Windows dropped when roof latch was released. Still nothing when the button is pressed.
The micro switch over the center latch is actually two switches in one.
One of them is working because you get the windows to drop but the second switch which controls the motor may not be working.
In a quiet environment push the micro switch pad with your finger very gently.
As it moves you should hear two clicks as each micro switch is activated.
If you only hear one click there's your answer.
I've also seen where the second micro switch is operational but the latch doesn't deactivate it because it's stuck and I've had to physically pull down on the pad to have the top work.
Happy Boxstering
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
