Old 05-20-2014, 01:13 PM   #11
healthservices
Registered Boxster abuser
healthservices's Avatar
Before using the air to hold the valve closed to change the spring, use the same air to carry out a leak down test. Might save you lots of heart ache.
And this was the assumption I thought was already done. If it does not seal with just air pressure under a leak down... putting in a new spring is not going to help.
