I believe I have. In a previous post I said that I found the two exhaust valves are not in sync with each other. One closes and the other stays open a bit when I spin the motor. Jake said that it is common for the lifters or the valve springs to fail. I've decided to pull the valve cover off and see what I can see. If it is a spring or lifter and I can replace in the car then that is my plan. If it ends up being more than that then I'll drop the engine and start reading...
