Old 05-19-2014, 09:55 PM   #11
aneal000
aneal000's Avatar
I believe I have. In a previous post I said that I found the two exhaust valves are not in sync with each other. One closes and the other stays open a bit when I spin the motor. Jake said that it is common for the lifters or the valve springs to fail. I've decided to pull the valve cover off and see what I can see. If it is a spring or lifter and I can replace in the car then that is my plan. If it ends up being more than that then I'll drop the engine and start reading...
aneal000 is offline   Reply With Quote
