According to the VIN, this Boxster is an RoW 2002 model, manufactured in Uusikaupinski, Finland.
There is no need to pull the radio retrieve the serial number. If you have a factory CDR-220:
Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob slowly, and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
When you get the serial number, either post it on this forum and Heiko may be able to supply the code, or you could go to the Rennlist forum, and Loren will provide it.
TO
