Old 05-19-2014, 11:12 AM   #4
spongebob
Once the door panel has been removed you will find the reinforcement plate.Remove the four bolts and lower the plate. Once done the two bolts holding the lock mechanism can be removed. A triple square bit is needed for this and the bolts are on the rear part of the door. Then it is possible to remove the lock part. Once taken out the handle can be removed. Two small nuts and two clips below the handle (inside door) holds it in place. However not needed in order to remove the door loch mechanism. When assembling the parts it was a little bit tricky to get the flat pin from the lock cylinder to end up in the correct place in the lock mechanism
spongebob is offline   Reply With Quote
