Old 05-19-2014, 10:38 AM   #17
kiyakubuke
RE: carbon fiber wrap
Originally Posted by whitecliffs View Post
Another 7kg gone, foam from around the engine bay, left a fair amount of glue
on the body work and was a pig to remove, even using WD40 to break down the glue.
But worth it for a nice clean finish.
Had a quick blast around without the carpet's fitted behind the seats and engine cover, noise level seemed ok nothing to high and light throttle was fine.
There's a fair bit of weigh in the 3 pieces covering the engine, the 2 carpets have a fair amount of foam giving scope to remove it.
Photo of the janspeed fitted.
So i've lost 74kg so far and for the moment that's it, the car has been off the road since the end of september and
it's time i got her back on the road again, so still looking to remove a few more kilos, but over a longer period......
Thought i'd add some weight, did a wrap on the center console came out looking good
thou it did take me around 4 hours
your skill level is way above mine. I tried several times to wrap the center console. never could get it looking good (ie. no bubbles or tears or creases). finally gave up, just going to hydro-dip it.
kiyakubuke is offline   Reply With Quote
