Old 05-18-2014, 08:20 PM   #14
kiyakubuke
I just replace the AOS and plugs. it was really only smoking on high revs under load.
after replacing the AOS is ran well and did not smoke, after driving it around easy for a while, I got on it a few times. shortly afterwards I noticed the the idle was a little high. checked for a vacuum leak and saw that I had damaged the oil filler tube while I was fighting with the AOS. took it off and fixed it, and put it back on. when I started it up again it was smoking like crazy and running rough. Tomorrow I will drive it around a little to see if it clears ups. if not, I have no idea.
kiyakubuke is offline   Reply With Quote
