Old 05-18-2014, 08:20 PM   #12
Ramos0513
Originally Posted by Ian c View Post
Now I'm home and on my iPad I can you your pics better ,
It looks like the rear is sticking out a good inch past the fender and the fronts look to be just about flush .
I think they're 8s and 11s 997 offset .
You can fit a porsche 5mm or h&r/ruf 7mm on the front to give a little more clearance , but you'll have to be carefull of hitting the fender on full compression if they're not fully rolled .
What size tyres on them and How is the clearance between tyre and lower spring basket ?
235/35zr19 for the front
275/35zr18 for the back
It does not rub at all when wheels are straight. It looks like so but it does not.
Problem comes in when I turn.
I was thinking I can just roll the inner fender ? If that's possible or the other option to cut , which I really don't want to do.
Ramos0513 is offline   Reply With Quote
