Old 05-18-2014, 04:14 PM   #18
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by kjc2050 View Post
I've never seen this as a requirement for removing the spark plug tubes... is this the commonly accepted practice? (I didn't remove the plugs before changing out the tubes when I did this recently, and didn't have any issues, so I'm curious.)
If you are going to use the bolt method, the spark plug may be in the way... besides spark plugs are partially made of porcelain and the last thing you want to do is cause another issue. Better safe, than sorry.
Transom tool grabs from the top of the plastic tube, the bolt method grabs from the bottom edge of the tube.
