Old 05-18-2014, 02:18 PM   #1
Ian c
Originally Posted by jsceash View Post
The distance from the outside face of the rim to the inside bolt surface. The bigger the offset the farther the tire sticks out. You can fix too little offset by adding spacers you can't fix to much offset. The second possibility is tire size.
They're measured from the centerline of the wheel as an ET . In millimeters .
The smaller number sticks out more. eg. Et25
The bigger number tucks in more . Eg Et35
You can make an et35 push out by adding a spacer to bring the et number down .
There is nothing you can do to bring in an et25 .
Hope this helps .
Ian c is offline   Reply With Quote
