Originally Posted by jsceash
The distance from the outside face of the rim to the inside bolt surface. The bigger the offset the farther the tire sticks out. You can fix too little offset by adding spacers you can't fix to much offset. The second possibility is tire size.
Got ya. I'll measure it in a bit.
But would it make a difference with spacers ? My outer fender is not the problem it's the inner one where it rubs.
