2001 986 Heater
Hi All
I am a member on the 911uk forum but no one seems to have an answer for my below problem, can anyone help ?
Well it has been 8 months since I last had my 2001 2.7 Boxster out to play.
The trouble is my heater is not putting out warm air when it is set manually anywhere between 18 to 29 on AC or none AC mode, you only get very hot air immediately if you set heater ti high.
Is this a known problem with a fix, I have read one problem that lay with the heater gate being full of holes after all the foam has broken down on it.
Any further help would be appreciated.
Regards
Neil.
