Old 05-17-2014, 01:46 PM   #1
LucasGelinstigues
Angry Secondary oil pump leak
A couple of days ago I noticed my car was leaking a little bit of oil, I then put the car up on the hoist to inspect it. I noticed that the secondary oil pump or commonly known as the scavenge pump was leaking. I then took the o ring off the pump, used some black gasket sealer, reset the o ring then covered it in another layer of the gasket sealer.
Now the interesting part, when I went to put the four 10mm bolts that hold the pump to the cylinder head/valve cover I noticed that the one of the bolts wasn't really getting any tighter. I took it out and saw that it looked like halfway up the bolt the threads had been stretched. So I put a new bolt in and the exact same thing happened. and now the damn thing is still leaking (less then before) however enough to piss me off !
Just wondering if anyone knows of any solutions to this problem or if anyone has had the same thing happen to them.
Thanks for all the help guys!
LucasGelinstigues is offline   Reply With Quote
