Stuck a needle into the two nozzles of the windshield washer. No harm in trying that to fix the windshield washers that do not work. Put additional w/s fluid in the tank but noticed the fluid ends up on the ground. W/s washer pump makes noise so that is not the problem so there must be a leak in the tank. Will go to automotive store to get a torx driver set......
Car has been pretty reliable for a few months and have only spent a $100 on non routine maintenance so far this year.
G.
