Old 05-15-2014, 10:05 AM   #3
healthservices
Registered Boxster abuser
healthservices's Avatar
Did you actually pour water down the drain holes to see if they do indeed go where they are suppose to? That's what I would do. If that is ok then I would start spraying the car to see where the water intrusion is coming from. Even pull up the back carpet and maybe even the seat to track it. Just remember if you pull the seat to disconnect the battery otherwise the SRS light will come on and wont come off without the proper tool.
