Old 05-14-2014, 11:44 AM   #10
shadrach74
Originally Posted by healthservices View Post
Also made a very short vid too. will take some time to up load...
That looks like way tooooo much work.
Do yourself a favor and get a set up like this:
1) transom plug - $5
2) just about any old redundant socket you have lying around. Free!
Using a dremel notch the socket so that it securely fits the "T" handle on the transom plug..
Insert the transom plug into the spark plug tube and then ratchet the T on top the plug using the notched out socket. It will tighten and then breaks loose, easily pulled from the cam cover.
With this set up, it takes approximately 30secs to remove a spark plug tube.
shadrach74 is offline   Reply With Quote
