Thread: Window issue
Old 05-14-2014, 06:46 AM   #6
sb01box
lightly pull on the door handle. if you hear the regulator motor then it's loose regulator cable .
also with the door opened, push down on the window, if it can be pushed down, also an indicator of loose cable.
if no window motor sound when the door handle is pulled, then it's the micro switch
try this on the passenger side door/window as reference point
sb01box is offline   Reply With Quote
