Old 03-11-2006, 07:34 AM   #1
bmussatti
Guest
Posts: n/a
valcax:
1) How often do you check your tire pressures, and when?
2) Is your tire pressure gage accurate? I recommend a digital readout.
3) You may want to switch to nitrogen fill on your tires, mainly because you will get far less pressure changes due to outside air temperature changes. I think tire pressures change about 2 pounds per 10 degrees of outside air temperature change. Nitrogen filled tires won't change as much, and stay more accurate. There are other advantages of nitrogen, but I think this is the best one, IMHO.
