Old 05-11-2014, 04:28 PM   #1
Lewischuck2000
New owner and member
I just got an '02 Boxster base with 130,000 miles on it. Am really happy so far. All that I know needs done is try to clean/polish the rear window and adjust the passenger window, it needs to drop down another ~2mm to clear the top.
I've been reading a lot about the IMS bearing but don't know what I should do. There are no oil leaks from under the car and I don't hear anything that sounds like a bad bearing. Being that this car has 130k on it, does that indicate the bearing has been changed in the past? Should it be changed again?
Thanks, Chuck
Lewischuck2000 is offline   Reply With Quote
