Old 05-11-2014, 09:58 AM   #1
TripleTrophy
First Porsche Oops
My top does not close quite right, so I usually pop it open a few inches and adjust the top just at the top back of the windows to make sure everything tucks in - it makes it quieter, and is probably more waterproof.
Friday on the way to work I had the top down and popped it up at the last red light before the highway. Got to work and since there was rain threatening in the afternoon, I went to pop it open to check the roof. Except in my haste I did not realize I had not flipped the lever all the way and when I pressed the switch I heard a bang. After thinking this is not good I closed the roof (moves easily by hand at this point) and consulted 101 Projects for your Boxster after a drive home in the rain. Inspection showed I had broken the plastic socket joints. I talked to the local dealer, and found, surprise, surprise, the full arms were in stock and not outrageously priced. Since I had managed to bend the arms in my playing with the roof (note to self, break the plastic sockets, don't play with the roof) I bought two and installed them. Easy job with the right tools. Pricing was compatible to Pelican, but next time I will try for the sockets only. Maybe a couple spare for the glove box.
BTW, there is a good link somewhere below showing the parts. Mine were white, and the new ones are white.
TripleTrophy is offline   Reply With Quote
