Old 05-10-2014, 06:57 PM   #12
DG Boxster
Noob no more
Thanks for your support guys. Today was my first attempt at Porsche maintenance. Because of your encouragement (and Pelican Parts!) it went pretty well.
Getting under the car was really easy - I used a set of Rhino Ramps which worked great in my garage, and jack stands for the front.
Oil & Filter change - OK! Found there was no washer on the oil drain plug, and installed the magnetic plug. Also replaced the filter housing since someone nearly tore through it with some sort of who knows what.
Cabin Air Filter change - OK!
Engine Air Filter - FAIL I'll post a thread about that one.
Power Steering Fluid - it was a tiny bit low, and there is a weird hose thing going on (another new thread).
Next is fuel filter, spark plugs, and a new plastic panel on the bottom of the car.
Thanks again!
DG Boxster is offline   Reply With Quote
