Old 05-08-2014, 11:51 AM   #19
markskyline
all that time I was convinced that the main feature of larger/expansive gauge cabling was focused on "professional shielding" to prevent noise, static and emi... other interferences loll
Not much to do with larger/faster data xfer = better sound quality
Was I wrong?
Quality wire will definitely help the sound quality. The rca's are ceptable to interference which can lead to engine whine through the stereo. Using proper Guage power wire is also important to the amps. For 99% of the installs on a box the amps will be in the frunk so the run isn't too long but still better to use thick power wire depending on how much power you're running.
Again just my opinion.
To the OP good luck with the install! The new stereo will sound better than the stock one for sure. Oh one last tip. Make sure you correctly connect the speakers polarity to your amp/head unit. You will definitely have poor bass response if you don't.
markskyline is offline   Reply With Quote
