Old 05-07-2014, 05:04 PM   #13
ELoomis
ELoomis's Avatar
Replacing the plug tubes is a good idea, but remember the law of gravity. Don't focus as much on where the oil is ending up. Start high on the engine, oil filler tube, AOS and it's tubing. The codes indicate air leak. Air leaks in, oil leaks out and is running down the side of your engine. I'll bet you also have a pool of oil on top of the engine below the oil filler tube.
ELoomis is offline   Reply With Quote
