Did you get this sorted as ive got a similar problem with my 2.5, my car pulls hard in all gears but seems to hold back above 5000rpm and struggles to hit the redline.
But and its most noticeable in 4th gear when its just above 5000rpm with the throttle fully open, if i start to slowly lift off the throttle the engine starts to pull and accelerate smooth to the redline, but if i open the throttle fully again it struggles.
lts seems like the engine getting to much air.
lve just fitted new coil packs and plugs and now looking to replace the MAF and lambda sensors.
