Old 05-05-2014, 03:22 AM   #10
JFP in PA
Jeff, thank you much for the picture it clearly shows the o-ring for the center bolt, however this O-ring seems to be on the 'engine side' of the bearing, which is a side that I will not have access because my bearing cannot be removed.
On the later engines (the ones you cannot remove the bearing) does the center bolt have the O-ring on the 'transmission side' of the bearing, meaning that I will be able to replace by removing the IMS cover?
If so, would you recommend installing a Viton seal (green color, high temp), since according to the dealer they do not offer a seal for the center bolt (or the center bolt itself) unless you buy the entire cover assembly @ only $140...
Sorry for asking so many questions... thank you for your support!
All OEM IMS have the O-ring in the transmission side of the bearing, so it will be out in the open when the cover is removed. Viton will be fine.
