Old 05-04-2014, 07:10 PM   #10
lkchris
lkchris's Avatar
Back in 2010 someone posted at Renntech ...
You need five wires. Three of one kind and two of another.
This corresponds with 101 projects instructions.
However, this was answered by ...
When I did my 2001 OBC, there was conflicting info on the wires. In 2001, Porsche changed the connectors and all the wires should be the same. You no longer need to cut and splice the 2 different VW wires, you will need 5 of the same. ... I'm pretty sure for 2001 and newer you will use 5 of the 000 979 009 wires. These go into stalk connectors 1 through 5. For connector 1, cut off the other end and add an eyelet to screw in to a good ground
Is this response that self-made harness wires can have same connector on both ends for 2001-up models correct?
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
