Old 05-04-2014, 11:20 AM   #19
mgfranz
Shifting issues solved, I first replaced the master and slave cylinder since this was a $67 shot just in case, figured with 86k on them it was cheap insurance anyway. But since changing them didn't fix the issue, I now have spares just in case.
I replaced the clutch, pressure plate, throwout bearing and flywheel bolts with new and even changed the flywheel with a NOS unit and the problem is gone, shifting is a breeze. But one thing I noticed is that the pedal pressure is a lot softer than before, I assume this has to do with the new plate.
But either way, problem solved, it was a lot of work, probably a total of 7 hours labor. I learned a lot about the back-half of my 986, and picked up a few trick along the way. Like it was easier to just disconnect the linkage from the tranny instead of trying to pop off the linkage from the ball fittings, and also that removing the exhaust in one piece is not saving any time since the unit has to be disassembled at the cat-back connectors anyway to get it back in. Also, plan on replacing the push-rivets that hold the spoiler cap in place, since they will probably break anyway. Reinstalling the slave cylinder before mounting the tranny mounts makes the install of the slave a breeze. Using a compressor driven vacuum bleeding system worked great to both drain and bleed the system.
So with a total of $596 spent on parts and new tools, my car is happy again. Thanks to everyone who chimed in with ideas and suggestions.
mgfranz is offline   Reply With Quote
