Old 05-03-2014, 08:07 AM   #12
BFeller
It is completely apart. I had to pull the little clips on black metal arms. I used a cooter pin removal tool to manipulate the clips into a position that allowed for removal. It only took two cut fingers before I put on the mechanics glove to spare the other eight.
The motor is running, the transmissions arms rotate forward and backwards. It does look like the pivot arm that attaches to the top, the one with the replaced ball socket, is slightly twisted. I can't say whether it happened when the bolt came out, or if it was from the previous owners incident. It is a subtle twist, in a part that already has some twist. I will order a replacement. I want to check the microswitches to make sure everything is shutting off when it should. It appears, that maybe the one that shuts motor off when the clam shell closes, failed and allowed the motor to beyond a safe limit. I need to figure that out. I think that would be the function of the switch/lever on the top of the motor.
