Thread: Clearing Debris
Old 05-02-2014, 08:12 PM   #1
balsalah
Two weeks ago when it rained, both of my front drains were clogged and I had about 1/2in of standing water in the battery compartment. Used compressed air to blow the junk out of the lines and all is well again!
By the way, the drivers side front drain is obscured by the brake booster, you have to really look under there to find it.
Also be careful not to push the upper lip of the rubber grommet of the drain tube down into the hole in the frame or it can be difficult to get it back up so it seals. Ask me how I know.
Its also a good time to replace the cabin air filter while your under the front covers.
I guess I need you help how did you get the upper grommet of the drain tube back up as push it all the way down is there a way to get to it anyone help will be appreciated
balsalah is offline   Reply With Quote
