In my case it seemed a little crazy to install a third AOS valve. but it must have came from the crankcase, because the smoke and wet intake stopped as soon as I removed the tube to the intake from the AOS valve.
If it did return I would think rings or valve seals...
Valve seals because the crank case pressure is forcing the oil past the valve stem seals
