Old 05-01-2014, 01:11 PM   #1
JFP in PA
Ok, the crank seal is not leaking, therefore I will leave it alone as this was replaced by the dealer during a pressure plate failure 2 1/2 years ago.
However, the cover for the IMS is seeping oil and I am trying to figure out how to replace the O-ring on the cover (without removing the bearing since it's an 07)..
My issue is that I have a BBI underdrive pulley that does not have the notch to show you TDC, it is a must to lock the crank at TDC in order to safely remove the IMS cover,
what else besides locking the crank at TDC is required (without messing anything else)..?
The pictures show the oil leak of 2 1/2 years, therefore is not too severe
To reseal the IMS cover, you have to remove it, and that requires doing everything needed to do an IMS swap (engine locked at TDC, cams locked, tensioners removed, etc.) , but without removing the bearing as it would not come out anyway. Along with replacing the three seals around the flange parameter, you also need to replace the center bolt seal and use green wicking Loctite on the center bolt threads.
