Old 05-01-2014, 05:34 AM   #1
Eric G
Theoretical propagandist
Eric G's Avatar
Originally Posted by Deserion View Post
Make sure to re-lube the points you used WD40 on since it's not a lubricant.
Does the stiffness feel like the clutch isn't in all the way (any grinding) or is just difficult to move in general? Wonder if the cables are getting stuck in the sheathing (doubt it but it could be plausible).
From WD40's own website:
Myth: WD-40 Multi-Use Product is not really a lubricant.
Fact: the “W-D” in WD-40 stands for Water Displacement, WD-40 Multi-Use Product is a unique, special blend of lubricants. The product’s formulation also contains anti-corrosion agents and ingredients for penetration, water displacement and soil removal.
